주요 콘텐츠로 건너뛰기
HP EliteBook x360 1030 G3 Wireless Card Replacement
필요한 것
  1. HP EliteBook x360 1030 G3 Wireless Card Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Wireless Card Replacement: 2 단계, 이미지 1/1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 1/2 HP EliteBook x360 1030 G3 Wireless Card Replacement, Wireless Card: 3 단계, 이미지 2/2
    • Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
    • These wires should be handled carefully since they're the Wi-Fi and Bluetooth antennas.
    • Take note of which wire goes where, as mixing these cables will cause both Wi-Fi and Bluetooth to stop working.
  4. HP EliteBook x360 1030 G3 Wireless Card Replacement: 4 단계, 이미지 1/1
    • Remove the 2.4 mm screw holding the card down using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Wireless Card Replacement: 5 단계, 이미지 1/2 HP EliteBook x360 1030 G3 Wireless Card Replacement: 5 단계, 이미지 2/2
    • Carefully pull out the card by sliding it to the left.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Shea Charkowsky
회원 가입일: 04/15/19
786 평판
안내서 3개 작성하였습니다
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 회원
CPSU-MANESS-S19S2G9
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 52
전체 시간: 2,207
