주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G5 Fan Replacement
필요한 것
  1. HP EliteBook x360 830 G5 Fan Replacement, Back Cover: 1 단계, 이미지 1/1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 Fan Replacement: 2 단계, 이미지 1/2 HP EliteBook x360 830 G5 Fan Replacement: 2 단계, 이미지 2/2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 Fan Replacement: 3 단계, 이미지 1/1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 Fan Replacement, Fan: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • With tweezers, pull back the retention tape that is attached to the fan cable.
  5. HP EliteBook x360 830 G5 Fan Replacement: 5 단계, 이미지 1/1
    • Use your fingers to carefully disconnect the fan cable from the motherboard.
  6. HP EliteBook x360 830 G5 Fan Replacement: 6 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, loosen the three screws that secure the fan to the motherboard.
  7. HP EliteBook x360 830 G5 Fan Replacement: 7 단계, 이미지 1/1
    • With two fingers, carefully lift the left edge of the fan and remove it from the board.
결론
Lea Duben
회원 가입일: 09/03/21
320 평판
안내서 3개 작성하였습니다
University of Alabama, Team 1-4, Bedsole Fall 2021 University of Alabama, Team 1-4, Bedsole Fall 2021 회원
UA-BEDSOLE-F21S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 351
