주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G5 M2 Solid State Drive Replacement
필요한 것
  1. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, Back Cover: 1 단계, 이미지 1/1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: 2 단계, 이미지 1/2 HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: 2 단계, 이미지 2/2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: 3 단계, 이미지 1/1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, M.2 Solid State Drive: 4 단계, 이미지 1/1
    • Pull the tab attached to the M.2 solid state drive shield up.
  5. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: 5 단계, 이미지 1/1
    • With the Phillips #1 screwdriver, loosen the single screw that secures the M.2 solid state drive to the system board.
  6. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: 6 단계, 이미지 1/1
    • Once the springs release, carefully remove the M.2 solid state drive.
    • Pull the SSD card gently so you don't bend any pins.
결론
Ashia Lewis
회원 가입일: 09/03/21
246 평판
안내서 2개 작성하였습니다
University of Alabama, Team 1-4, Bedsole Fall 2021 University of Alabama, Team 1-4, Bedsole Fall 2021 회원
UA-BEDSOLE-F21S1G4
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 25
전체 시간: 568
