주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G6 Cooling System Replacement
필요한 것
  1. HP EliteBook x360 830 G6 Cooling System Replacement, Unfasten the back cover: 1 단계, 이미지 1/1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: 2 단계, 이미지 1/2 HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: 2 단계, 이미지 2/2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: 3 단계, 이미지 1/2 HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: 3 단계, 이미지 2/2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: 4 단계, 이미지 1/3 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: 4 단계, 이미지 2/3 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: 4 단계, 이미지 3/3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: 5 단계, 이미지 1/3 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: 5 단계, 이미지 2/3 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: 5 단계, 이미지 3/3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: 6 단계, 이미지 1/3 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: 6 단계, 이미지 2/3 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: 6 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the seven 3 mm screws from the cooling system.
  7. HP EliteBook x360 830 G6 Cooling System Replacement: 7 단계, 이미지 1/3 HP EliteBook x360 830 G6 Cooling System Replacement: 7 단계, 이미지 2/3 HP EliteBook x360 830 G6 Cooling System Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the three 3mm captive screws from the fan using the Philips 0 screwdriver.
    • Using needle nose tweezers, gently grab the base of the connection and pull to disconnect.
  8. HP EliteBook x360 830 G6 Cooling System Replacement: 8 단계, 이미지 1/1
    • Separate the fan and cooling system from the motherboard.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Bukari
회원 가입일: 09/01/21
97 평판
안내서 1개 작성함
Gateway, Team 1-2, Saknee Fall 2021 Gateway, Team 1-2, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 26
전체 시간: 529
