주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G6 Motherboard Replacement
필요한 것
  1. HP EliteBook x360 830 G6 Motherboard Replacement, Unfasten the back cover: 1 단계, 이미지 1/1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Motherboard Replacement, Release the clips: 2 단계, 이미지 1/2 HP EliteBook x360 830 G6 Motherboard Replacement, Release the clips: 2 단계, 이미지 2/2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Motherboard Replacement, Release the remaining clips: 3 단계, 이미지 1/2 HP EliteBook x360 830 G6 Motherboard Replacement, Release the remaining clips: 3 단계, 이미지 2/2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Motherboard Replacement, Remove the back cover: 4 단계, 이미지 1/3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the back cover: 4 단계, 이미지 2/3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the back cover: 4 단계, 이미지 3/3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the battery: 5 단계, 이미지 1/3 HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the battery: 5 단계, 이미지 2/3 HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the battery: 5 단계, 이미지 3/3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Motherboard Replacement, Unfasten the battery: 6 단계, 이미지 1/1
    • Use your Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
  7. HP EliteBook x360 830 G6 Motherboard Replacement, Remove the battery: 7 단계, 이미지 1/3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the battery: 7 단계, 이미지 2/3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the battery: 7 단계, 이미지 3/3
    • Pull the battery out from the retaining tabs at the front of the chassis.
    • Remove the battery.
  8. HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the SSD cover: 8 단계, 이미지 1/3 HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the SSD cover: 8 단계, 이미지 2/3 HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the SSD cover: 8 단계, 이미지 3/3
    • With your spudger, pry up on the tabs at the top and bottom of the SSD cover.
    • This will loosen the SSD cover enough for it to pop out from its tension clips.
  9. HP EliteBook x360 830 G6 Motherboard Replacement, Remove the SSD cover: 9 단계, 이미지 1/2 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the SSD cover: 9 단계, 이미지 2/2
    • Lift the SSD cover off the SSD and remove it.
  10. HP EliteBook x360 830 G6 Motherboard Replacement, Unfasten the SSD: 10 단계, 이미지 1/2 HP EliteBook x360 830 G6 Motherboard Replacement, Unfasten the SSD: 10 단계, 이미지 2/2
    • Use your Phillips screwdriver to remove the 2.4 mm-long screw from the SSD.
  11. HP EliteBook x360 830 G6 Motherboard Replacement, Remove the SSD: 11 단계, 이미지 1/3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the SSD: 11 단계, 이미지 2/3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the SSD: 11 단계, 이미지 3/3
    • Grip the edges if the SSD near the screw indent.
    • Pull the SSD straight out of its socket and remove it.
    • If the SSD feels stuck, wiggle it side to side as you pull.
  12. HP EliteBook x360 830 G6 Motherboard Replacement, CMOS Battery: 12 단계, 이미지 1/3 HP EliteBook x360 830 G6 Motherboard Replacement, CMOS Battery: 12 단계, 이미지 2/3 HP EliteBook x360 830 G6 Motherboard Replacement, CMOS Battery: 12 단계, 이미지 3/3
    • Use your fingers or the pointed end of a spudger disconnect the CMOS battery connector.
  13. HP EliteBook x360 830 G6 Motherboard Replacement: 13 단계, 이미지 1/1
    • Remove the CMOS battery from its housing by pulling up the small, black plastic tab that is holding it in place.
  14. HP EliteBook x360 830 G6 Motherboard Replacement, Cooling System: 14 단계, 이미지 1/3 HP EliteBook x360 830 G6 Motherboard Replacement, Cooling System: 14 단계, 이미지 2/3 HP EliteBook x360 830 G6 Motherboard Replacement, Cooling System: 14 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the seven 3 mm screws from the cooling system.
  15. HP EliteBook x360 830 G6 Motherboard Replacement: 15 단계, 이미지 1/3 HP EliteBook x360 830 G6 Motherboard Replacement: 15 단계, 이미지 2/3 HP EliteBook x360 830 G6 Motherboard Replacement: 15 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the three 3mm captive screws from the fan using the Philips 0 screwdriver.
    • Using needle nose tweezers, gently grab the base of the connection and pull to disconnect.
  16. HP EliteBook x360 830 G6 Motherboard Replacement: 16 단계, 이미지 1/1
    • Separate the fan and cooling system from the motherboard.
  17. HP EliteBook x360 830 G6 Motherboard Replacement, Wi-Fi Card: 17 단계, 이미지 1/2 HP EliteBook x360 830 G6 Motherboard Replacement, Wi-Fi Card: 17 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the two antenna cable with tweezers.
    • The blue tagged antenna will be on the left side. The red tagged antenna will be on the right side.
  18. HP EliteBook x360 830 G6 Motherboard Replacement: 18 단계, 이미지 1/2 HP EliteBook x360 830 G6 Motherboard Replacement: 18 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the 3 mm screw securing the Wi-Fi card.
    • The card will pop up at a slight angle once the screw is removed.
  19. HP EliteBook x360 830 G6 Motherboard Replacement: 19 단계, 이미지 1/2 HP EliteBook x360 830 G6 Motherboard Replacement: 19 단계, 이미지 2/2
    • Grasp the sides of the Wi-Fi card to slide it out of the socket to remove.
    • Gently remove the Wi-Fi card. There is risk of damage to the socket if removed forcefully.
  20. HP EliteBook x360 830 G6 Motherboard Replacement, Motherboard: 20 단계, 이미지 1/3 HP EliteBook x360 830 G6 Motherboard Replacement, Motherboard: 20 단계, 이미지 2/3 HP EliteBook x360 830 G6 Motherboard Replacement, Motherboard: 20 단계, 이미지 3/3
    • Remove each no-fuss ribbon connector by gently pulling the blue tab straight away from the port with your fingers.
    • To disconnect the ZIF connectors, use the tip of your fingernail to flip up the small locking flap. Then disconnect the ribbon cables.
    • Grab the black plastic loop of each of the connectors pull it upwards away from the motherboard.
    • When pulling out the ribbon, do not pull up and away from the laptop. Doing so may damage the ribbon or socket.
  21. HP EliteBook x360 830 G6 Motherboard Replacement: 21 단계, 이미지 1/3 HP EliteBook x360 830 G6 Motherboard Replacement: 21 단계, 이미지 2/3 HP EliteBook x360 830 G6 Motherboard Replacement: 21 단계, 이미지 3/3
    • Remove the metal shield that covers the RAM module.
    • Gently pull the two silver retaining arms apart until the module flips up a few millimeters.
    • Remove the RAM module.
    • Pull the memory card straight back out of its slot to avoid damage to either part.
  22. HP EliteBook x360 830 G6 Motherboard Replacement: 22 단계, 이미지 1/2 HP EliteBook x360 830 G6 Motherboard Replacement: 22 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the five 4.1 mm screws from the plastic bracket.
    • Remove the bracket.
  23. HP EliteBook x360 830 G6 Motherboard Replacement: 23 단계, 이미지 1/2 HP EliteBook x360 830 G6 Motherboard Replacement: 23 단계, 이미지 2/2
    • Push in then remove the SD card slot from the side of the laptop.
  24. HP EliteBook x360 830 G6 Motherboard Replacement: 24 단계, 이미지 1/2 HP EliteBook x360 830 G6 Motherboard Replacement: 24 단계, 이미지 2/2
    • Remove the remaining cords connecting to the motherboard near the top.
  25. HP EliteBook x360 830 G6 Motherboard Replacement: 25 단계, 이미지 1/2 HP EliteBook x360 830 G6 Motherboard Replacement: 25 단계, 이미지 2/2
    • Gently lift and remove the motherboard.
    • Do not tug or forcefully pull the motherboard to remove it. If there is any significant resistance, double check that all previous steps were completed and all accessories are removed.
결론
Brody Reder
회원 가입일: 04/02/24
301 평판
안내서 3개 작성하였습니다
IUPUI, Team 3-3, Harley Spring 2024 IUPUI, Team 3-3, Harley Spring 2024 회원
IUPUI-HARLEY-S24S3G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 53
전체 시간: 78
