소개
This guide will instruct you on how to safely remove and replace the motherboard in your HP Elitebook x360 830 G6. Removing your motherboard is a significant repair to your laptop and requires careful maneuvering of all parts included to ensure nothing gets broken. Keep in mind that the connections between certain parts and the motherboard are fragile. Excessive force to remove, or replace, any part should not be needed. If you find yourself straining to remove, or replace, a part, please review the steps to ensure you are doing it correctly. Proper storage of every part and screw is extremely important when completing this guide. When taking any hardware off of the motherboard, place it somewhere safe as you will need to install it onto your new motherboard.
필요한 것
Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
Pry upward to release the retaining clips.
Repeat this process for the opposite corner.
Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
Pry up to release the additional retaining clips.
Grab the cover by the corners next to the hinges.
Swing the cover open and away from you.
Lift and remove the back cover from the laptop body.
Use the point of a spudger to push the sides of the battery connector out of its socket.
Push on alternate sides to "walk" the connector out.
Use your Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
Pull the battery out from the retaining tabs at the front of the chassis.
Remove the battery.
With your spudger, pry up on the tabs at the top and bottom of the SSD cover.
Use your Phillips screwdriver to remove the 2.4 mm-long screw from the SSD.
Grip the edges if the SSD near the screw indent.
Pull the SSD straight out of its socket and remove it.
Use your fingers or the pointed end of a spudger disconnect the CMOS battery connector.
Using the Phillips #0 screwdriver, remove the seven 3 mm screws from the cooling system.
Remove each no-fuss ribbon connector by gently pulling the blue tab straight away from the port with your fingers.
To disconnect the ZIF connectors, use the tip of your fingernail to flip up the small locking flap. Then disconnect the ribbon cables.
Grab the black plastic loop of each of the connectors pull it upwards away from the motherboard.
