주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G7 Battery Replacement
필요한 것
  1. HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: 1 단계, 이미지 1/3 HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: 1 단계, 이미지 2/3 HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: 1 단계, 이미지 3/3
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Battery Replacement, Disconnect the bundled cable connector: 2 단계, 이미지 1/1
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Battery Replacement, Peel the copper foil tape: 3 단계, 이미지 1/2 HP EliteBook x360 830 G7 Battery Replacement, Peel the copper foil tape: 3 단계, 이미지 2/2
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Battery Replacement, Remove the screws: 4 단계, 이미지 1/2 HP EliteBook x360 830 G7 Battery Replacement, Remove the screws: 4 단계, 이미지 2/2
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: 5 단계, 이미지 1/3 HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: 5 단계, 이미지 2/3 HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: 5 단계, 이미지 3/3
    • Remove the battery from the laptop.
결론
Emily Kaplan
회원 가입일: 03/21/22
217 평판
안내서 2개 작성하였습니다
University of Alabama, Team 2-1, Bedsole Spring 2022 University of Alabama, Team 2-1, Bedsole Spring 2022 회원
UA-BEDSOLE-S22S2G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 53
전체 시간: 930
