주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G7 Display Replacement
필요한 것
  1. HP EliteBook x360 830 G7 Display Replacement, Remove the display: 1 단계, 이미지 1/3 HP EliteBook x360 830 G7 Display Replacement, Remove the display: 1 단계, 이미지 2/3 HP EliteBook x360 830 G7 Display Replacement, Remove the display: 1 단계, 이미지 3/3
    • Use an opening tool to remove the display from the laptop case. Place it in the area that you see the most give.
    • If you hear the plastic tabs "snapping" free, you should be fine.
    • Be careful not to crack the display.
  2. HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: 2 단계, 이미지 1/3 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: 2 단계, 이미지 2/3 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: 2 단계, 이미지 3/3
    • With the screen removed, locate the pair of wires hidden underneath the two pieces of tape.
  3. HP EliteBook x360 830 G7 Display Replacement, Connector bracket: 3 단계, 이미지 1/2 HP EliteBook x360 830 G7 Display Replacement, Connector bracket: 3 단계, 이미지 2/2
    • Use a plastic opening tool or nylon spudger to lift the metal digitizer-connector bracket.
  4. HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: 4 단계, 이미지 1/3 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: 4 단계, 이미지 2/3 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: 4 단계, 이미지 3/3
    • Now that the bracket is removed, pull the golden connector away from the silver base.
    • Now, the back of the display should look like this.
  5. HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: 5 단계, 이미지 1/3 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: 5 단계, 이미지 2/3 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: 5 단계, 이미지 3/3
    • The next piece of tape that needs to be peeled, but not removed, is highlighted by the red rectangle.
    • Peel but do not remove the black piece of tape.
  6. HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: 6 단계, 이미지 1/3 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: 6 단계, 이미지 2/3 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: 6 단계, 이미지 3/3
    • Peel, but do not remove entirely, the clear piece of tape that was underneath the black tape.
  7. HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: 7 단계, 이미지 1/3 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: 7 단계, 이미지 2/3 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: 7 단계, 이미지 3/3
    • Pull the small, bronze "Brighton" ribbon cable connector from the tan connection base.
  8. HP EliteBook x360 830 G7 Display Replacement, Separate the display housing from the computer: 8 단계, 이미지 1/1
    • If you can move your display's housing away from the computer, then you have successfully detached your display and can replace it.
결론
Jonathan Bond
회원 가입일: 03/21/22
207 평판
안내서 1개 작성함
University of Alabama, Team 2-1, Bedsole Spring 2022 University of Alabama, Team 2-1, Bedsole Spring 2022 회원
UA-BEDSOLE-S22S2G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 12
30일 전: 56
전체 시간: 1,396
