주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G7 Display Replacement
필요한 것
  1. HP EliteBook x360 830 G7 Display Replacement, Remove the display: 1 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Display Replacement, Remove the display: 1 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Display Replacement, Remove the display: 1 단계, 이미지 3개 중 3개
    • Use an opening tool to remove the display from the laptop case. Place it in the area that you see the most give.
    • If you hear the plastic tabs "snapping" free, you should be fine.
    • Be careful not to crack the display.
  2. HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: 2 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: 2 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: 2 단계, 이미지 3개 중 3개
    • With the screen removed, locate the pair of wires hidden underneath the two pieces of tape.
  3. HP EliteBook x360 830 G7 Display Replacement, Connector bracket: 3 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Display Replacement, Connector bracket: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool or nylon spudger to lift the metal digitizer-connector bracket.
  4. HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: 4 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: 4 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: 4 단계, 이미지 3개 중 3개
    • Now that the bracket is removed, pull the golden connector away from the silver base.
    • Now, the back of the display should look like this.
  5. HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: 5 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: 5 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: 5 단계, 이미지 3개 중 3개
    • The next piece of tape that needs to be peeled, but not removed, is highlighted by the red rectangle.
    • Peel but do not remove the black piece of tape.
  6. HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: 6 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: 6 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: 6 단계, 이미지 3개 중 3개
    • Peel, but do not remove entirely, the clear piece of tape that was underneath the black tape.
  7. HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: 7 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: 7 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: 7 단계, 이미지 3개 중 3개
    • Pull the small, bronze "Brighton" ribbon cable connector from the tan connection base.
  8. HP EliteBook x360 830 G7 Display Replacement, Separate the display housing from the computer: 8 단계, 이미지 1개 중 1개
    • If you can move your display's housing away from the computer, then you have successfully detached your display and can replace it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jonathan Bond
회원 가입일: 03/21/22
277 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 67
전체 시간: 2,482
