주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G7 RAM Replacement
필요한 것
  1. HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: 1 단계, 이미지 1/2 HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: 1 단계, 이미지 2/2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: 2 단계, 이미지 1/3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: 2 단계, 이미지 2/3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: 2 단계, 이미지 3/3
    • Gently lift the larger, rectangular metal shielding off. This shielding covers the RAM.
  3. HP EliteBook x360 830 G7 RAM Replacement, Remove the RAM: 3 단계, 이미지 1/1
    • Push down on the two latches on both sides of the RAM to release it.
    • This will allow you to remove the RAM and replace it with no issues.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Abigail Herring
회원 가입일: 03/21/22
165 평판
안내서 1개 작성함
University of Alabama, Team 2-1, Bedsole Spring 2022 University of Alabama, Team 2-1, Bedsole Spring 2022 회원
UA-BEDSOLE-S22S2G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 12
30일 전: 54
전체 시간: 1,103
