주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G7 Speakers Replacement
필요한 것
  1. HP EliteBook x360 830 G7 Speakers Replacement, Remove the backplate: 1 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Speakers Replacement, Remove the backplate: 1 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Speakers Replacement, Remove the backplate: 1 단계, 이미지 3개 중 3개
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Speakers Replacement, Disconnect the bundled cable connector: 2 단계, 이미지 1개 중 1개
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Speakers Replacement, Peel the copper foil tape: 3 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Speakers Replacement, Peel the copper foil tape: 3 단계, 이미지 2개 중 2개
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Speakers Replacement, Remove the screws: 4 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Speakers Replacement, Remove the screws: 4 단계, 이미지 2개 중 2개
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Speakers Replacement, Remove the battery: 5 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Speakers Replacement, Remove the battery: 5 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Speakers Replacement, Remove the battery: 5 단계, 이미지 3개 중 3개
    • Remove the battery from the laptop.
  6. HP EliteBook x360 830 G7 Speakers Replacement, Speakers: 6 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Speakers Replacement, Speakers: 6 단계, 이미지 2개 중 2개
    • Gently pinch the white tab and pull the speaker cable out of its socket.
    • Don't pull on the cables.
    • If you can't get the speaker cable out by hand, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
  7. HP EliteBook x360 830 G7 Speakers Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the right and left speakers from the laptop.
    • There is a wire connecting the two speakers that is still attached to the laptop, so do not pull the speakers apart or away from the device.
    • Disconnect the speaker wire from the wire hooks along the edge of the chassis.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jaila Crum
회원 가입일: 09/12/23
91 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 23
전체 시간: 276
