주요 콘텐츠로 건너뛰기
HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement
필요한 것
  1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: 1 단계, 이미지 1/3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: 1 단계, 이미지 2/3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: 1 단계, 이미지 3/3
    • Place the computer screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: 2 단계, 이미지 1/3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: 2 단계, 이미지 2/3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: 2 단계, 이미지 3/3
    • Grasp the handle on the hard drive cage to the left of the stand. It is marked with green.
    • Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer.
    • Pull the entire cage up and out of the device.
  3. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: 3 단계, 이미지 1/2 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: 3 단계, 이미지 2/2
    • Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side.
    • Once all the screws are removed, lift the drive out of the cage.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Kyle Koivuniemi
회원 가입일: 10/01/15
605 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-24, Maness Fall 2015 Cal Poly, Team 1-24, Maness Fall 2015 회원
CPSU-MANESS-F15S1G24
4 회원들
안내서 14개 작성하였습니다
댓글 2개
where can i buy a replace cage for the hard drive?
Thomas Dickson - 답글
What replacement guide can I buy for my HP EliteOne 800 G1 all in one?
Hank Trujillo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 19
30일 전: 53
전체 시간: 8,364
