소개
This guide is to be used in the case of a power supply that has begun to give out. Power supply failure can be recognized through symptoms such as slower run time, or issues with pace of processing,
필요한 것
Place computer with the screen down on a flat surface.
Push the two locking latches to the unlocked position.
Push the cover toward the top of the computer and lift up.
Press locking latch on the bottom of the base of the stand.
Pull the plastic cover off of the stand.
Use a Torx T15 driver to remove the four 10mm screws on the VESA mount cover.
Lift up on the VESA mount cover to remove it.
다른 6명이 해당 안내서를 완성하였습니다.
