소개
Use this guide to replace the battery in your HP ElitePad 900.
필요한 것
다른 13명이 해당 안내서를 완성하였습니다.
댓글 2개
One way to remove screen assembly without a suction cup is to use a piece of duct tape folded onto to itself leaving a small amount of the adhesive portion exposed. This creates a little handle. You can then stick it to assembly and lift it out easily.
Matt Brunk - 답글
