주요 콘텐츠로 건너뛰기
HP ElitePad 900 Volume Control Buttons Replacement
필요한 것
  1. HP ElitePad 900 Volume Control Buttons Replacement, Front Panel Assembly: 1 단계, 이미지 1/1
    • Unscrew the two 2.8mm Phillips #000 screws near the power connector.
  2. HP ElitePad 900 Volume Control Buttons Replacement: 2 단계, 이미지 1/2 HP ElitePad 900 Volume Control Buttons Replacement: 2 단계, 이미지 2/2
    • Use a suction cup to pull the display assembly up.
  3. HP ElitePad 900 Volume Control Buttons Replacement: 3 단계, 이미지 1/2 HP ElitePad 900 Volume Control Buttons Replacement: 3 단계, 이미지 2/2
    • Use the tip of a spudger to disconnect the two display ZIF connectors.
  4. HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: 4 단계, 이미지 1/3 HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: 4 단계, 이미지 2/3 HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: 4 단계, 이미지 3/3
    • Using the Phillips screwdriver remove the two 2.4mm #000 screws that are securing the volume control buttons to the device.
    • Lift up the silver panel, removing it completely from the device
    • Push the buttons through the slot to remove them from the device
결론
Kyle Marques
회원 가입일: 09/03/15
889 평판
안내서 6개 작성하였습니다
USF Tampa, Team 12-4, Blackwell Fall 2015 USF Tampa, Team 12-4, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 675
