소개
There are 2 RAM slots in the 6930p Laptop. One is the expansion slot and accessible from the underside of the device, the other is the default location for factory installed RAM and is located under the keyboard. This guide focuses on the expansion slot
필요한 것
Flip laptop over and locate the battery release button
Push release button to the left to release battery and gently pull battery from the laptop
Locate the RAM expansion slot cover on the bottom of the laptop
Loosen the PM2.0×5.0 captive screw and remove the cover.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 17개
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Can you add an 8GB DDR2 6400 to your laptop (HP6930p) without upgrading or changing the factory installed one? The label on the bottom of mine says C2D P8700 2.53 GHz 4GB.
Thanks for any help!
Thank you for information.
By p8slot.com
sutep Fifa - 답글
