주요 콘텐츠로 건너뛰기
HP Elitebook 6930p RAM (Expansion Slot) Replacement
필요한 것
  1. HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: 1 단계, 이미지 1/3 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: 1 단계, 이미지 2/3 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: 1 단계, 이미지 3/3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): 2 단계, 이미지 1/2 HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): 2 단계, 이미지 2/2
    • Locate the RAM expansion slot cover on the bottom of the laptop
    • Loosen the PM2.0×5.0 captive screw and remove the cover.
  3. HP Elitebook 6930p RAM (Expansion Slot) Replacement: 3 단계, 이미지 1/2 HP Elitebook 6930p RAM (Expansion Slot) Replacement: 3 단계, 이미지 2/2
    • Install RAM module into the RAM slot on an angle of around 30 degrees
    • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
    • Check to ensure the metal tabs are holding the RAM module down on both sides
    • Reinstall the RAM cover
결론
다른 8명이 해당 안내서를 완성하였습니다.
Richdave
회원 가입일: 04/09/10
32,150 평판
안내서 30개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,468개 작성하였습니다
댓글 17개
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - 답글
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Jan Cerenohorsky -
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - 답글
Can you add an 8GB DDR2 6400 to your laptop (HP6930p) without upgrading or changing the factory installed one? The label on the bottom of mine says C2D P8700 2.53 GHz 4GB.
Thanks for any help!
Brian Fenech - 답글
Thank you for information.
By p8slot.com
sutep Fifa - 답글
Thanks for such amazing stuff. Please keep sharing.
<a href="https://168slotxo.net/the-secert-slot-on...>ความลับของสล็อตออนไลน์ในคาสิโน</a>
Shoaib - 답글
Thanks for such an amazing stuff. Please keep sharing.
<a href="https://168slotxo.net/168slotxo-the-best...>สล็อตออนไลน์</a>
Shoaib - 답글
You always share so amazing articles. I really love it.
slotxo
Shoaib - 답글
You always share so amazing articles. I love it.
slotxo
Shoaib - 답글
I am a big fan of your site and content.
pg
Shoaib - 답글
I am a big fan of your site and amazing content.
pgslot
Shoaib - 답글
Your content is always awesome.
pg
Shoaib - 답글
Your site is awesome. I will recommend this to everyone.
pg slot
Shoaib - 답글
Thanks for this information, please can i add 8gb to my expansion slot and leave the other 2gb that is under the keyboard?
Emeba Okeoghene - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 53
전체 시간: 15,552
