주요 콘텐츠로 건너뛰기
HP Elitebook 820 G1 Hard Drive Replacement
필요한 것
  1. HP Elitebook 820 G1 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Remove the four 8mm screws with the T7 philip's head.
  6. HP Elitebook 820 G1 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove the hard drive casing.
    • Unscrew the four 8mm Philips screws holding the hard drive.
  7. HP Elitebook 820 G1 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Remove the hard drive from the casing and replace it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alberto Carlos Perez
회원 가입일: 02/14/18
365 평판
안내서 2개 작성하였습니다
USF Tampa, Team S5-G1, Eyestone Spring 2018 USF Tampa, Team S5-G1, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 27
전체 시간: 3,787
