주요 콘텐츠로 건너뛰기
HP Elitebook 820 G1 Monitor Display Replacement
필요한 것
  1. HP Elitebook 820 G1 Monitor Display Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Monitor Display Replacement: 2 단계, 이미지 1/1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Monitor Display Replacement: 3 단계, 이미지 1/1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Monitor Display Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Monitor Display Replacement, Fan: 5 단계, 이미지 1/1
    • Remove the hard drive by unscrewing the four 8mm screws with the T7 philip's head.
  6. HP Elitebook 820 G1 Monitor Display Replacement: 6 단계, 이미지 1/1
    • Pry off ten rubber paddings on the outer edge of the laptop to reveal the torx screws.
    • Unscrew the ten 8mm torx screws that are under the rubber paddings using the T7 tip torx screwdriver.
  7. HP Elitebook 820 G1 Monitor Display Replacement: 7 단계, 이미지 1/1
    • Remove the two 4mm screws indicated by the M2.5X4 using the J00 tip screwdriver.
    • Remove SD card cap by just sliding out to reveal one screw.
  8. HP Elitebook 820 G1 Monitor Display Replacement: 8 단계, 이미지 1/1
    • Remove the two 3mm screws indicated by the M2.03 using the J00 tip screwdriver.
    • Remove the 4mm SD card screw using the J00 tip.
  9. HP Elitebook 820 G1 Monitor Display Replacement: 9 단계, 이미지 1/1
    • Remove the one 4mm fan screw using the J00 tip screwdriver.
    • Remove screw and metal plate to expose ribbon cable connector.
  10. HP Elitebook 820 G1 Monitor Display Replacement: 10 단계, 이미지 1/1
    • Use an opening tool to pry up the ribbon connector to disconnect.
  11. HP Elitebook 820 G1 Monitor Display Replacement: 11 단계, 이미지 1/1
    • Turn laptop over back to normal position as shown in the image.
    • Use opening tools to pry up keyboard.
    • When prying up keyboard, be sure to start near any corner of the keyboard.
    • There are two ribbon cables that must be disconnected before fully removing keyboard.
  12. HP Elitebook 820 G1 Monitor Display Replacement: 12 단계, 이미지 1/3 HP Elitebook 820 G1 Monitor Display Replacement: 12 단계, 이미지 2/3 HP Elitebook 820 G1 Monitor Display Replacement: 12 단계, 이미지 3/3
    • Carefully lift keyboard on one side to expose the two ribbon cables.
    • Use an opening tool to lift up the locking clip and unplug the two ribbon cables.
  13. HP Elitebook 820 G1 Monitor Display Replacement: 13 단계, 이미지 1/1
    • Remove the two 4mm screws centered notated by the keyboard logo using the J00 tip.
  14. HP Elitebook 820 G1 Monitor Display Replacement: 14 단계, 이미지 1/3 HP Elitebook 820 G1 Monitor Display Replacement: 14 단계, 이미지 2/3 HP Elitebook 820 G1 Monitor Display Replacement: 14 단계, 이미지 3/3
    • Once keyboard has been fully removed, the system case containing the motherboard can be lifted out easily.
    • The display is connected to the shell of the laptop.
  15. HP Elitebook 820 G1 Monitor Display Replacement: 15 단계, 이미지 1/1
    • Unplug fan cable by pulling away from its connector.
  16. HP Elitebook 820 G1 Monitor Display Replacement: 16 단계, 이미지 1/1
    • Unscrew the two 6mm fan screws using the J00 tip.
    • Fan screws are encased in springs and cannot be removed.
  17. HP Elitebook 820 G1 Monitor Display Replacement, Monitor display: 17 단계, 이미지 1/1
    • Retrieve the monitor display connected to the plastic chassis.
  18. HP Elitebook 820 G1 Monitor Display Replacement: 18 단계, 이미지 1/1
    • Unscrew the two 4mm hinge screws using the Philips 00 tip screwdriver.
  19. HP Elitebook 820 G1 Monitor Display Replacement: 19 단계, 이미지 1/1
    • Unhinge the monitor display from the chassis.
결론
Alberto Carlos Perez
회원 가입일: 02/14/18
365 평판
안내서 2개 작성하였습니다
USF Tampa, Team S5-G1, Eyestone Spring 2018 USF Tampa, Team S5-G1, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G1
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Hello,
I need to replace the inverter as my screen is too much dark.
I cannot see the inverter and even I cannot find any inverter for this model.
Do you know how to access to this inverter? Is it embedded within the screen?
Thanks by advance.
BR
richard P - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 31
전체 시간: 3,269
