주요 콘텐츠로 건너뛰기
HP Elitebook 820 G2 RAM Replacement
  1. HP Elitebook 820 G2 RAM Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 HP Elitebook 820 G2 RAM Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Slide the lever firmly to the left on the back panel.
    • Once the back panel is unlocked, there should be red showing to the right of the lever.
  2. HP Elitebook 820 G2 RAM Replacement: 2 단계, 이미지 2개 중 1개 HP Elitebook 820 G2 RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the back panel towards you.
    • Lift the back panel to remove it.
  3. HP Elitebook 820 G2 RAM Replacement, RAM: 3 단계, 이미지 1개 중 1개
    • Undo the clips on the sides of the RAM chips by pushing them away from the RAM.
    • Too much pressure might snap the clips.
  4. HP Elitebook 820 G2 RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Once the clips are unfastened, use a plastic spudger to lightly pry up the RAM chips.
    • Grab the RAM chips, remove them, and set them aside.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
KaitLyn Teubert
회원 가입일: 02/25/19
502 평판
안내서 2개를 작성함
댓글 한 개
Hi KaitLyn Teubert
Thank you for your HP Elitebook 820 G2 RAM Replacement tutorial
Currently, I have 2 HP Elitebook 820 G2 notebook, and I have problem with one of my HP Elitebook 820 G2.
RAM is not detected. I have tried to replace the RAM to another HP Elitebook 820 G2, and also buy new RAM but its doesn't work at all.
May you have any suggestion to my problem?
Thank you.
Jaya Ma - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 42
전체 시간: 1,805
