주요 콘텐츠로 건너뛰기
HP Elitebook 8460p Bluetooth Card Replacement
  1. HP Elitebook 8460p Bluetooth Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Bluetooth Card Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Bluetooth Card Replacement, Back Panel: 3 단계, 이미지 1개 중 1개
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Bluetooth Card Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Bluetooth Card Replacement, Bluetooth Card: 5 단계, 이미지 2개 중 1개 HP Elitebook 8460p Bluetooth Card Replacement, Bluetooth Card: 5 단계, 이미지 2개 중 2개
    • Attach an ESD strap to your wrist and to a ground.
    • Using a fingernail, grasp the small connector and separate the connector from the Bluetooth card.
  6. HP Elitebook 8460p Bluetooth Card Replacement: 6 단계, 이미지 1개 중 1개
    • Grasp the Bluetooth card and pull it straight out to the left.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Garrett Anderson
회원 가입일: 09/16/19
2,250 평판
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 27
지난 30일: 66
전체 시간: 5,594
