이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
Slide the battery away from the switches until it can be lifted away from the laptop.
Lift the battery away from the laptop.
On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
Slide the back shell of the laptop away from the switches until it can be lifted up.
Lift the shell straight up.
Using a Phillips #0 bit, unscrew the two screws on opposite corners of the fan.
Disconnect the small electrical connector. Pry the edge up with your finger nails or using a small plastic pry tool.
Pry the inside edge up, pulling the entire assembly to the inside of the laptop, exposing the processor and graphics processor
Blow compressed air through the vent from the outside and through the heat sink.
다른 2명이 해당 안내서를 완성하였습니다.
