주요 콘텐츠로 건너뛰기
HP Elitebook 8460p Hard Drive Replacement
필요한 것
  1. HP Elitebook 8460p Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
    what if it does not work,what does that mean?
    julia melrose - 답글
  2. HP Elitebook 8460p Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Hard Drive Replacement, Back Panel: 3 단계, 이미지 1/1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Hard Drive Replacement: 4 단계, 이미지 1/1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/2 HP Elitebook 8460p Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/2
    • Attach an ESD strap to your wrist and to a ground.
    • Pull the tab with the small engraved arrow up and towards the inside of the laptop.
  6. HP Elitebook 8460p Hard Drive Replacement: 6 단계, 이미지 1/2 HP Elitebook 8460p Hard Drive Replacement: 6 단계, 이미지 2/2
    • Using a Phillips #0 bit, unscrew the three screws that hold the hard drive assembly in place.
  7. HP Elitebook 8460p Hard Drive Replacement: 7 단계, 이미지 1/2 HP Elitebook 8460p Hard Drive Replacement: 7 단계, 이미지 2/2
    • Remove the silver metal cover by pulling straight up on the black tab.
  8. HP Elitebook 8460p Hard Drive Replacement: 8 단계, 이미지 1/1
    • Disconnect the hard drive by pulling the drive straight out to the left.
    • If replacing the hard drive, seat the new hard drive firmly in the connector.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Garrett Anderson
회원 가입일: 09/16/19
2,184 평판
안내서 10개 작성하였습니다
댓글 4개
Thanks! This made hard drive replacement on Elitebook VERY Easy!
Patrick Murphy - 답글
Awesome! So glad that it was able to help you out and keep your Elitebook running. Have a wonderful day!
Garrett Anderson -
Now it won't see the new HD to install to. W10 says the drive can't be used for booting and to enable it in BIOS.
Can't find where to enable it, however.
Rich Frueh - 답글
Meh. Took out battery, let sit for a while. Hit power a few times, plugged back in, and presto!
Not my favorite HP laptop.
Rich Frueh -
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 28
30일 전: 114
전체 시간: 6,025
