주요 콘텐츠로 건너뛰기
HP Elitebook 8460p Keyboard Replacement
필요한 것
  1. HP Elitebook 8460p Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Keyboard Replacement, Back Panel: 3 단계, 이미지 1개 중 1개
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 1개 HP Elitebook 8460p Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 2개 HP Elitebook 8460p Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 3개
    • Attach ESD strap around your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws in front of the battery slot located on the bottom of the laptop.
  6. HP Elitebook 8460p Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Flip the laptop over and open the screen.
  7. HP Elitebook 8460p Keyboard Replacement: 7 단계, 이미지 3개 중 1개 HP Elitebook 8460p Keyboard Replacement: 7 단계, 이미지 3개 중 2개 HP Elitebook 8460p Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Using a spudger, work around the edge of the keyboard and pry it up from the device.
  8. HP Elitebook 8460p Keyboard Replacement: 8 단계, 이미지 2개 중 1개 HP Elitebook 8460p Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the keyboard out of the laptop and flip it over.
    • This exposes two different connectors. Both need to be detached in order to remove the keyboard. The larger connector is the main keyboard cable.
  9. HP Elitebook 8460p Keyboard Replacement: 9 단계, 이미지 2개 중 1개 HP Elitebook 8460p Keyboard Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the keyboard cable on the laptop using a thin pry tool to open the connection.
    • Open the connection by inserting a thin plastic pry tool under the black tab in the connector and flipping it up.
  10. HP Elitebook 8460p Keyboard Replacement: 10 단계, 이미지 2개 중 1개 HP Elitebook 8460p Keyboard Replacement: 10 단계, 이미지 2개 중 2개
    • Using the spudger again, disconnect the thin ribbon strip on the back of the keyboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Garrett Anderson
회원 가입일: 09/16/19
2,250 평판
안내서 10개를 작성함
댓글 2개
There's a third keyboard screw right beside the fan
Colin Chaplin - 답글
yeah just wanted to say this ...
Also the screws are PH1 not PH0
Robert Kohari -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 43
전체 시간: 4,149
