주요 콘텐츠로 건너뛰기
HP Elitebook 8460p Modem Card Replacement
필요한 것
  1. HP Elitebook 8460p Modem Card Replacement, Battery: 1 단계, 이미지 1/1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Modem Card Replacement: 2 단계, 이미지 1/1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Modem Card Replacement, Back Panel: 3 단계, 이미지 1/1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Modem Card Replacement: 4 단계, 이미지 1/1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Modem Card Replacement, Modem Card: 5 단계, 이미지 1/2 HP Elitebook 8460p Modem Card Replacement, Modem Card: 5 단계, 이미지 2/2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, remove the two 3.0 mm screws and set them off to the side side on a magnetic surface.
  6. HP Elitebook 8460p Modem Card Replacement: 6 단계, 이미지 1/2 HP Elitebook 8460p Modem Card Replacement: 6 단계, 이미지 2/2
    • Push down on one corner of the sound card and lift it straight up.
  7. HP Elitebook 8460p Modem Card Replacement: 7 단계, 이미지 1/2 HP Elitebook 8460p Modem Card Replacement: 7 단계, 이미지 2/2
    • Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Garrett Anderson
회원 가입일: 09/16/19
2,157 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 31
전체 시간: 1,493
