주요 콘텐츠로 건너뛰기
HP Elitebook 8460p Modem Card Replacement
필요한 것
  1. HP Elitebook 8460p Modem Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Modem Card Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Modem Card Replacement, Back Panel: 3 단계, 이미지 1개 중 1개
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Modem Card Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Modem Card Replacement, Modem Card: 5 단계, 이미지 2개 중 1개 HP Elitebook 8460p Modem Card Replacement, Modem Card: 5 단계, 이미지 2개 중 2개
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, remove the two 3.0 mm screws and set them off to the side side on a magnetic surface.
  6. HP Elitebook 8460p Modem Card Replacement: 6 단계, 이미지 2개 중 1개 HP Elitebook 8460p Modem Card Replacement: 6 단계, 이미지 2개 중 2개
    • Push down on one corner of the sound card and lift it straight up.
  7. HP Elitebook 8460p Modem Card Replacement: 7 단계, 이미지 2개 중 1개 HP Elitebook 8460p Modem Card Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Garrett Anderson
회원 가입일: 09/16/19
2,250 평판
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 36
전체 시간: 1,732
