주요 콘텐츠로 건너뛰기
HP Elitebook 8460p Optical Drive Replacement
필요한 것
  1. HP Elitebook 8460p Optical Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Optical Drive Replacement, Back Panel: 3 단계, 이미지 1개 중 1개
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: 5 단계, 이미지 3개 중 1개 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: 5 단계, 이미지 3개 중 2개 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: 5 단계, 이미지 3개 중 3개
    • Using a Phillips #0 bit, unscrew the one Phillips head screw.
    • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
  6. HP Elitebook 8460p Optical Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Elitebook 8460p Optical Drive Replacement: 6 단계, 이미지 2개 중 2개
    • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
  7. HP Elitebook 8460p Optical Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Elitebook 8460p Optical Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Elitebook 8460p Optical Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
    • Using a small paper clip, push the paper clip straight in to open the optical drive.
  8. HP Elitebook 8460p Optical Drive Replacement: 8 단계, 이미지 3개 중 1개 HP Elitebook 8460p Optical Drive Replacement: 8 단계, 이미지 3개 중 2개 HP Elitebook 8460p Optical Drive Replacement: 8 단계, 이미지 3개 중 3개
    • Using a small point, pop the tab out.
    • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Garrett Anderson
회원 가입일: 09/16/19
2,304 평판
안내서 10개를 작성함
1가이드 댓글
Thanks for your help sir and I am really grateful
Mubarak Abubakar - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 1,328
