주요 콘텐츠로 건너뛰기
HP Elitebook 8460p RAM (Random Access Memory) Replacement
필요한 것
  1. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Battery: 1 단계, 이미지 1/1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p RAM (Random Access Memory) Replacement: 2 단계, 이미지 1/1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Back Panel: 3 단계, 이미지 1/1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p RAM (Random Access Memory) Replacement: 4 단계, 이미지 1/1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): 5 단계, 이미지 1/3 HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): 5 단계, 이미지 2/3 HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): 5 단계, 이미지 3/3
    • Attach ESD strap around your wrist and to a ground.
    • Using both thumbs, locate the two metal clips and pull them apart, allowing the RAM chip to pop upwards.
  6. HP Elitebook 8460p RAM (Random Access Memory) Replacement: 6 단계, 이미지 1/2 HP Elitebook 8460p RAM (Random Access Memory) Replacement: 6 단계, 이미지 2/2
    • Pull the RAM chip straight out and repeat for the second chip.
    • If installing new RAM chip(s), seat the chip firmly in the RAM slot and push down until the metal clips snap in place.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Garrett Anderson
회원 가입일: 09/16/19
2,184 평판
안내서 10개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 35
전체 시간: 2,001
