주요 콘텐츠로 건너뛰기
HP Elitebook 8570w Display Replacement
필요한 것
  1. HP Elitebook 8570w Display Replacement, Display: 1 단계, 이미지 1/3 HP Elitebook 8570w Display Replacement, Display: 1 단계, 이미지 2/3 HP Elitebook 8570w Display Replacement, Display: 1 단계, 이미지 3/3
    • With the computer opened, locate the square buttons on both bottom corners of the display.
    • Using a tool or finger, wedge the squares off revealing a screw on each corner.
  2. HP Elitebook 8570w Display Replacement: 2 단계, 이미지 1/1
    • Use a T9 screwdriver to unscrew both 0.4mm Torx screws.
  3. HP Elitebook 8570w Display Replacement: 3 단계, 이미지 1/2 HP Elitebook 8570w Display Replacement: 3 단계, 이미지 2/2
    • Use an opening tool or spudger to peel back the outer rim of the display.
    • Continue to peel back the entire rim.
  4. HP Elitebook 8570w Display Replacement: 4 단계, 이미지 1/1
    • Unscrew ONLY the bottom 0.8mm T9 Torx screw on both sides of the display.
  5. HP Elitebook 8570w Display Replacement: 5 단계, 이미지 1/3 HP Elitebook 8570w Display Replacement: 5 단계, 이미지 2/3 HP Elitebook 8570w Display Replacement: 5 단계, 이미지 3/3
    • Now locate the two screws on each side at the bottom of the display.
    • TOP screw: unscrew partially.
    • BOTTOM screw: completely unscrew and set to the side.
    • Complete on both sides of display.
    • Carefully separate the display from the top cover.
    • Be sure to not let the top cover fall back
  6. HP Elitebook 8570w Display Replacement: 6 단계, 이미지 1/2 HP Elitebook 8570w Display Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to unscrew all four 0.8 mm screws from the left side of the display frame. Repeat for the right side.
    • Push the metal plates/rods that were attached to the display towards the top cover.
    • The display should be completely free of the top cover and able to lay flat on the keyboard (refer to photo #2).
  7. HP Elitebook 8570w Display Replacement: 7 단계, 이미지 1/3 HP Elitebook 8570w Display Replacement: 7 단계, 이미지 2/3 HP Elitebook 8570w Display Replacement: 7 단계, 이미지 3/3
    • With the display laying on the keyboard, locate the black square panel marked in the photo.
    • Grab the side marked in photo #2 and pull it towards you peeling off the surrounding tape and releasing it from the actual display board.
    • This will then remove the connection between the display and the top cover.
결론
다른 4명이 해당 안내서를 완성하였습니다.
MJ Routh
회원 가입일: 11/06/17
461 평판
안내서 3개 작성하였습니다
Baylor, Team S8-G5, Johnson Fall 2017 Baylor, Team S8-G5, Johnson Fall 2017 회원
BU-JOHNSON-F17S8G5
3 회원들
안내서 4개 작성하였습니다
댓글 2개
this guide is really bad, dangerous and should be removed !
at step 3 you crack and kill the existing display. If it was still somewhat working before now you are assured it is completely dead !
adrenochrome - 답글
agreed, step 3 should use the opening tool on a top corner of the bezel, not against the screen. you just screwed up the screen if it worked at all
Hidden Djinn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 3,523
