주요 콘텐츠로 건너뛰기
HP Elitebook 8570w Hard Drive Replacement
필요한 것
  1. HP Elitebook 8570w Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • To begin, you will need to remove the battery by sliding the left slider (red) to the left.
    • Push the battery away from you to release it.
    • Then, use the right slider to remove the computer's backing (shown in image)
    • Slide the backing towards you to remove it.
  2. HP Elitebook 8570w Hard Drive Replacement: 2 단계, 이미지 1/1
    • Once the backing has been removed, you will be able to locate the computer's hard drive in the bottom left corner.
  3. HP Elitebook 8570w Hard Drive Replacement: 3 단계, 이미지 1/1
    • To remove the hard drive compartment's cover, unscrew the two 0.8mm Phillips screws with a P1 Phillips-head screwdriver.
    • Open by lifting the left side of the cover so it is facing upwards and outwards.
    • The black screws, not the gold screws.
  4. HP Elitebook 8570w Hard Drive Replacement: 4 단계, 이미지 1/1
    • Use the same screwdriver to loosen all three screws at the attachment points of the silver hard drive caddy.
    • These screws do not need to be completely removed.
  5. HP Elitebook 8570w Hard Drive Replacement: 5 단계, 이미지 1/1
    • To remove the caddy and gain access to the hard drive, pull the black tab up to release it from the caddy.
    • Once you can grab the tab with your fingers, pull it to the left to disconnect the hard drive from the computer.
  6. HP Elitebook 8570w Hard Drive Replacement: 6 단계, 이미지 1/1
    • The hard drive can now be replaced inside the caddy.
결론
다른 5명이 해당 안내서를 완성하였습니다.
MJ Routh
회원 가입일: 11/06/17
465 평판
안내서 3개 작성하였습니다
Baylor, Team S8-G5, Johnson Fall 2017 Baylor, Team S8-G5, Johnson Fall 2017 회원
BU-JOHNSON-F17S8G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 42
전체 시간: 14,401
