주요 콘텐츠로 건너뛰기
HP Elitebook 8570w Keyboard Replacement
필요한 것
  1. HP Elitebook 8570w Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Begin by removing the back cover of the computer.
    • Push the marked slider to the right.
    • While pushing the slider, pull the cover towards yourself to remove.
  2. HP Elitebook 8570w Keyboard Replacement: 2 단계, 이미지 1/1
    • Locate the 3 screws marked in the photo.
    • Using a Phillips screwdriver, unscrew all 3 0.8mm screws completely and place to the side.
  3. HP Elitebook 8570w Keyboard Replacement: 3 단계, 이미지 1/2 HP Elitebook 8570w Keyboard Replacement: 3 단계, 이미지 2/2
    • Flip the computer so it is laying on its side.
    • Using your fingers or a tool, begin to wedge back/pull off the top of the keyboard panel.
    • Once freeing the keyboard panel from the computer, it should look like photo #2.
  4. HP Elitebook 8570w Keyboard Replacement: 4 단계, 이미지 1/1
    • Locate all 3 places of attachment marked in the photo.
    • Each de-attachment is explained in the following steps.
  5. HP Elitebook 8570w Keyboard Replacement: 5 단계, 이미지 1/2 HP Elitebook 8570w Keyboard Replacement: 5 단계, 이미지 2/2
    • Locate the white rectangle base beneath the blue and white strip attached to the computer and keyboard.
    • Using a wedging tool, pull the white base up slightly to loosen the grip on the blue and white strip.
    • With the white base slightly risen, use tweezers to carefully pull out/remove the strip from the computer.
  6. HP Elitebook 8570w Keyboard Replacement: 6 단계, 이미지 1/2 HP Elitebook 8570w Keyboard Replacement: 6 단계, 이미지 2/2
    • Locate the white rectangle base beneath the burn orange strip attached to the computer and the keyboard.
    • Like the previous step, use a plastic or nylon tool to slightly raise the white base to loosen the grip on the ribbon cable.
    • Using tweezers or your fingers, carefully pull up on the ribbon cable to completely detach it from the computer.
  7. HP Elitebook 8570w Keyboard Replacement: 7 단계, 이미지 1/1
    • Locate the black rectangle base at the bottom of the thick ribbon cable.
    • Like previous steps, use a tool to wedge the base upward to slightly lift it in order to loosen the grip on the silver ribbon cable.
    • While the base is lifted, use your fingers to carefully pull out the silver ribbon cable thus freeing it from the computer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Marko Tardio
회원 가입일: 11/06/17
226 평판
안내서 1개 작성함
Baylor, Team S8-G5, Johnson Fall 2017 Baylor, Team S8-G5, Johnson Fall 2017 회원
BU-JOHNSON-F17S8G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 29
전체 시간: 7,272
