주요 콘텐츠로 건너뛰기
HP Elitebook 8570w Optical Drive Replacement
필요한 것
  1. HP Elitebook 8570w Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Begin by removing the computers back covering.
    • Use the right slider to unlock the backing.
    • Slide the backing towards you while holding the slider to remove it.
  2. HP Elitebook 8570w Optical Drive Replacement: 2 단계, 이미지 1/1
    • Once the backing is removed, locate the panel to the left where the optical drive is stored.
    • Locate the single screw in the photo.
    • Unscrew the 0.8mm Phillips screw and place to the side.
  3. HP Elitebook 8570w Optical Drive Replacement: 3 단계, 이미지 1/1
    • Locate the small metal piece in the photo.
    • Using a tool, push the piece in the given direction.
  4. HP Elitebook 8570w Optical Drive Replacement: 4 단계, 이미지 1/2 HP Elitebook 8570w Optical Drive Replacement: 4 단계, 이미지 2/2
    • Once pushing the piece outwards, the optical drive will pop out of the side of the computer.
    • Grab the optical drive and carefully remove it from the back of the computer.
결론
MJ Routh
회원 가입일: 11/06/17
465 평판
안내서 3개 작성하였습니다
Baylor, Team S8-G5, Johnson Fall 2017 Baylor, Team S8-G5, Johnson Fall 2017 회원
BU-JOHNSON-F17S8G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 1,747
