주요 콘텐츠로 건너뛰기
HP Elitebook Folio 9470m Keyboard Replacement
필요한 것
  1. HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HP Elitebook Folio 9470m Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove battery by pushing slide over to red, lifting slightly up while pulling the battery out.
  3. HP Elitebook Folio 9470m Keyboard Replacement: 3 단계, 이미지 3개 중 1개 HP Elitebook Folio 9470m Keyboard Replacement: 3 단계, 이미지 3개 중 2개 HP Elitebook Folio 9470m Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Remove hard drive cover plate by unscrewing the 2 Phillips head screws and lifting slightly up and out.
  4. HP Elitebook Folio 9470m Keyboard Replacement: 4 단계, 이미지 3개 중 1개 HP Elitebook Folio 9470m Keyboard Replacement: 4 단계, 이미지 3개 중 2개 HP Elitebook Folio 9470m Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Remove back cover by unscrewing the 3 Phillips head screws, then lift the plate up and out.
  5. HP Elitebook Folio 9470m Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 4 Phillips head keyboard screws.
    • The screws are also marked with small keyboard icons to distinguish them.
  6. HP Elitebook Folio 9470m Keyboard Replacement: 6 단계, 이미지 3개 중 1개 HP Elitebook Folio 9470m Keyboard Replacement: 6 단계, 이미지 3개 중 2개 HP Elitebook Folio 9470m Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Flip the laptop over and locate the 2 tabs on the left or right sides. They will be slightly visible in the space between the keyboard and frame.
    • Using a plastic opening tool, push the tabs in while pulling up to disconnect the tabs from the keyboard frame.
    • Once both tabs become unclipped, lift the keyboard up gently allowing it to slightly bend as the front and back tabs come out.
  7. HP Elitebook Folio 9470m Keyboard Replacement: 7 단계, 이미지 2개 중 1개 HP Elitebook Folio 9470m Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • While lifting the keyboard up only enough to see underneath, unclip and remove the ribbon wire to fully detach the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Kenneth Bowers
회원 가입일: 04/08/16
1,432 평판
안내서 7개를 작성함
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 UMass Dartmouth, Team S1-G1, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S1G1
4 회원들
안내서 19개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 60
전체 시간: 5,781
