주요 콘텐츠로 건너뛰기
HP Elitebook x360 1030 G2 Battery Replacement
필요한 것
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
  1. HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: 2 단계, 이미지 2개 중 1개 HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: 2 단계, 이미지 2개 중 2개
    • Remove the five Torx-4 T4M2.0×7.4 shoulder screws that secure the bottom cover to the computer.
    • Use a spudger to separate the rear edge of the bottom cover and the keyboard/top cover.
    • Remove the bottom cover by sliding it up and back at an angle.
  2. HP Elitebook x360 1030 G2 Battery Replacement, Remove the battery: 3 단계, 이미지 1개 중 1개
    • Disconnect the battery cable from the system board.
    • Remove the six Phillips PM2.0×5.3 screws that secure the battery to the keyboard/top cover.
    • Remove the battery.
결론
To replace the battery & reassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Max Kletskov
회원 가입일: 04/22/20
40,850 평판
안내서 16개를 작성함
The Home Depot The Home Depot 회원
Community
18,029 회원들
안내서 140개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 38
지난 30일: 122
전체 시간: 5,440
