주요 콘텐츠로 건너뛰기
HP Elitebook x360 1040 G5 Fan Replacement
필요한 것
  1. HP Elitebook x360 1040 G5 Fan Replacement, Lower Case: 1 단계, 이미지 1/2 HP Elitebook x360 1040 G5 Fan Replacement, Lower Case: 1 단계, 이미지 2/2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Fan Replacement: 2 단계, 이미지 1/2 HP Elitebook x360 1040 G5 Fan Replacement: 2 단계, 이미지 2/2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Fan Replacement, Fan: 3 단계, 이미지 1/2 HP Elitebook x360 1040 G5 Fan Replacement, Fan: 3 단계, 이미지 2/2
    • Use the Phillips 0 screwdriver to remove the six 3mm Phillips screws from the fan assembly.
  4. HP Elitebook x360 1040 G5 Fan Replacement: 4 단계, 이미지 1/2 HP Elitebook x360 1040 G5 Fan Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Carefully remove the two wires connecting the fan to the mother board by pulling on both sides of the head.
    • If the wires are difficult to remove, you may need a pair of tweezers to help unplug the wire.
    • If you use tweezers be very gentle, because the wires are fragile.
  5. HP Elitebook x360 1040 G5 Fan Replacement: 5 단계, 이미지 1/2 HP Elitebook x360 1040 G5 Fan Replacement: 5 단계, 이미지 2/2
    • Remove the two pins, on the left of the fan by gently pulling on the connector.
    • Push them to the side, as they can get caught on the fan.
    • The white tagged wire goes on the right and the black tagged wire goes on the left.
  6. HP Elitebook x360 1040 G5 Fan Replacement: 6 단계, 이미지 1/2 HP Elitebook x360 1040 G5 Fan Replacement: 6 단계, 이미지 2/2
    • Remove the black sticker covering part of the fan by pulling up on one of it's corners.
  7. HP Elitebook x360 1040 G5 Fan Replacement: 7 단계, 이미지 1/3 HP Elitebook x360 1040 G5 Fan Replacement: 7 단계, 이미지 2/3 HP Elitebook x360 1040 G5 Fan Replacement: 7 단계, 이미지 3/3
    • Use the Phillips 00 screwdriver to remove the five 3mm Phillips screws from the heat sink assembly.
    • Take hold of the fan assembly. Push down and toward yourself until the clips are released, then pull the fans from the device.
  8. HP Elitebook x360 1040 G5 Fan Replacement: 8 단계, 이미지 1/2 HP Elitebook x360 1040 G5 Fan Replacement: 8 단계, 이미지 2/2
    • Remove the thermal paste heatsink using a lint-free cloth. Then with few drops of Isopropyl alcohol remove the any residue.
    • 99% Isopropyl alcohol is preferred, but 70% is acceptable.
    • New thermal paste needs to be applied before reassembling the fan.
결론
  • To reassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Corey Agena
회원 가입일: 04/21/19
794 평판
안내서 6개 작성하였습니다
Cal Poly, Team S1-G4, Maness Spring 2019 Cal Poly, Team S1-G4, Maness Spring 2019 회원
CPSU-MANESS-S19S1G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 27
전체 시간: 884
