주요 콘텐츠로 건너뛰기
HP Elitebook x360 1040 G5 Screen display Replacement
필요한 것
  1. HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: 1 단계, 이미지 3개 중 1개 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: 1 단계, 이미지 3개 중 2개 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: 1 단계, 이미지 3개 중 3개
    • Open your laptop.
    • Apply heat to the perimeter of screen display using the low setting on the heat gun or hair dryer. Keep the heat gun at least 6 inches away from the device at all time to prevent damage to other components.
    • Continue to apply heat for 5 to 10 minutes.
  2. HP Elitebook x360 1040 G5 Screen display Replacement: 2 단계, 이미지 3개 중 1개 HP Elitebook x360 1040 G5 Screen display Replacement: 2 단계, 이미지 3개 중 2개 HP Elitebook x360 1040 G5 Screen display Replacement: 2 단계, 이미지 3개 중 3개
    • Using the jimmy tool pry outward on the screen display, starting near one of the top corners.
    • Carefully pry along the perimeter of the display until the screen can be easily removed.
    • Lay the screen face down on the keyboard for the next step.
  3. HP Elitebook x360 1040 G5 Screen display Replacement: 3 단계, 이미지 2개 중 1개 HP Elitebook x360 1040 G5 Screen display Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully remove the clear adhesive protector from the smallest ribbon cable, located closest to the laptop hinge.
    • Gently slide the connector out of the harness, moving it towards the side of the laptop with the power button.
  4. HP Elitebook x360 1040 G5 Screen display Replacement: 4 단계, 이미지 3개 중 1개 HP Elitebook x360 1040 G5 Screen display Replacement: 4 단계, 이미지 3개 중 2개 HP Elitebook x360 1040 G5 Screen display Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully remove the clear adhesive protector from the last ribbon cable, located on the large black strip on the back of the screen display.
    • Gently remove the ribbon cable from the harness by moving it toward the laptop hinge.
  5. HP Elitebook x360 1040 G5 Screen display Replacement: 5 단계, 이미지 3개 중 1개 HP Elitebook x360 1040 G5 Screen display Replacement: 5 단계, 이미지 3개 중 2개 HP Elitebook x360 1040 G5 Screen display Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the screen from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tyler A Cobb
회원 가입일: 09/03/19
321 평판
안내서 2개를 작성함
IUPUI, Team S1-G1, Hovde Fall 2019 IUPUI, Team S1-G1, Hovde Fall 2019 회원
IUPUI-HOVDE-F19S1G1
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 64
전체 시간: 2,351
