주요 콘텐츠로 건너뛰기
HP Elitebook x360 1040 G5 Speakers Replacement
필요한 것
  1. HP Elitebook x360 1040 G5 Speakers Replacement, Lower Case: 1 단계, 이미지 2개 중 1개 HP Elitebook x360 1040 G5 Speakers Replacement, Lower Case: 1 단계, 이미지 2개 중 2개
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Speakers Replacement: 2 단계, 이미지 2개 중 1개 HP Elitebook x360 1040 G5 Speakers Replacement: 2 단계, 이미지 2개 중 2개
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Speakers Replacement, Battery: 3 단계, 이미지 2개 중 1개 HP Elitebook x360 1040 G5 Speakers Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Speakers Replacement: 4 단계, 이미지 3개 중 1개 HP Elitebook x360 1040 G5 Speakers Replacement: 4 단계, 이미지 3개 중 2개 HP Elitebook x360 1040 G5 Speakers Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
  5. HP Elitebook x360 1040 G5 Speakers Replacement, Speakers: 5 단계, 이미지 2개 중 1개 HP Elitebook x360 1040 G5 Speakers Replacement, Speakers: 5 단계, 이미지 2개 중 2개
    • Use the Phillips 0 screwdriver to remove the four 3mm Phillips screws from the speaker assembly.
  6. HP Elitebook x360 1040 G5 Speakers Replacement: 6 단계, 이미지 3개 중 1개 HP Elitebook x360 1040 G5 Speakers Replacement: 6 단계, 이미지 3개 중 2개 HP Elitebook x360 1040 G5 Speakers Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully remove the plug, connecting the speaker assembly to the motherboard on the right hand side, by pulling on either side of its head.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Corey Agena
회원 가입일: 04/21/19
833 평판
안내서 6개를 작성함
Cal Poly, Team S1-G4, Maness Spring 2019 Cal Poly, Team S1-G4, Maness Spring 2019 회원
CPSU-MANESS-S19S1G4
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 718
