주요 콘텐츠로 건너뛰기
HP Elitebook x360 1040 G5 Touchpad Replacement
필요한 것
  1. HP Elitebook x360 1040 G5 Touchpad Replacement, Lower Case: 1 단계, 이미지 1/2 HP Elitebook x360 1040 G5 Touchpad Replacement, Lower Case: 1 단계, 이미지 2/2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Touchpad Replacement: 2 단계, 이미지 1/2 HP Elitebook x360 1040 G5 Touchpad Replacement: 2 단계, 이미지 2/2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Touchpad Replacement, Battery: 3 단계, 이미지 1/2 HP Elitebook x360 1040 G5 Touchpad Replacement, Battery: 3 단계, 이미지 2/2
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Touchpad Replacement: 4 단계, 이미지 1/3 HP Elitebook x360 1040 G5 Touchpad Replacement: 4 단계, 이미지 2/3 HP Elitebook x360 1040 G5 Touchpad Replacement: 4 단계, 이미지 3/3
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
  5. HP Elitebook x360 1040 G5 Touchpad Replacement, Touchpad: 5 단계, 이미지 1/2 HP Elitebook x360 1040 G5 Touchpad Replacement, Touchpad: 5 단계, 이미지 2/2
    • Use the Phillips 0 screwdriver to remove the six 3mm Phillips screws from the touchpad assembly.
  6. HP Elitebook x360 1040 G5 Touchpad Replacement: 6 단계, 이미지 1/3 HP Elitebook x360 1040 G5 Touchpad Replacement: 6 단계, 이미지 2/3 HP Elitebook x360 1040 G5 Touchpad Replacement: 6 단계, 이미지 3/3
    • Gently pull on the blue tab to remove the ribbon connecting the touchpad to the motherboard on the left hand side.
    • Gently pull on the blue tab to remove the ribbon connecting the touchpad to the motherboard on the right hand side.
  7. HP Elitebook x360 1040 G5 Touchpad Replacement: 7 단계, 이미지 1/1
    • Gently pull up on the top two corners of the touchpad and remove it from the laptop.
결론
Corey Agena
회원 가입일: 04/21/19
794 평판
안내서 6개 작성하였습니다
Cal Poly, Team S1-G4, Maness Spring 2019 Cal Poly, Team S1-G4, Maness Spring 2019 회원
CPSU-MANESS-S19S1G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 648
