소개
Hard drives may become damaged or faulty through unfortunate accidents or prolonged use over time. They can also have too little memory space or be too slow at accessing and saving your personal data. Change out your old HP Envy 14 hard drive for a new one with these steps.
필요한 것
Slide the battery cover release latch to eject the battery cover outwards.
Remove the battery cover.
Take your new hard drive and insert it into the hard drive bracket in the same position as the original hard drive.
The hard drive should be face up such that the hard drive connectors can be seen.
The screw holders on the open ends of the hard drive bracket should be on the top.
The screw holders on the opposite side of the hard drive bracket should be on the bottom.
To reassemble your HP Envy 14 with your new hard drive, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Please add a new guide for the newer 2015 hp 14 envy variant(with a hinge lifting mechanism)
Remin jose - 답글
