주요 콘텐츠로 건너뛰기
HP Envy 14 Screen Replacement
필요한 것
  1. HP Envy 14 Screen Replacement, Screen: 1 단계, 이미지 1/2 HP Envy 14 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • With your laptop turned off and facing down, locate the battery.
    • Slide and hold the black tabs while removing the battery. One of the black tabs may lock in place once slided over.
  2. HP Envy 14 Screen Replacement: 2 단계, 이미지 1/3 HP Envy 14 Screen Replacement: 2 단계, 이미지 2/3 HP Envy 14 Screen Replacement: 2 단계, 이미지 3/3
    • Flip your laptop back over and open it up.
    • The black circles are stickers.
    • Peel off the 2 black stickers directly above the two hinges to reveal the screws.
  3. HP Envy 14 Screen Replacement: 3 단계, 이미지 1/2 HP Envy 14 Screen Replacement: 3 단계, 이미지 2/2
    • Use the 4mm Phillips Srewdriver to remove the 2 screws you just uncovered.
    • Make sure to put the 2 screws in a safe place so that you don't lose them! A small bowl or container would work perfectly.
  4. HP Envy 14 Screen Replacement: 4 단계, 이미지 1/2 HP Envy 14 Screen Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Use the plastic card or your fingernail to separate the black plastic border from the screen case.
    • You will hear a snapping sound but don't worry, you are not breaking the plastic, the border will snap right back into place!
  5. HP Envy 14 Screen Replacement: 5 단계, 이미지 1/3 HP Envy 14 Screen Replacement: 5 단계, 이미지 2/3 HP Envy 14 Screen Replacement: 5 단계, 이미지 3/3
    • Separate the border entirely by unsnapping the plastic snaps all the way around the screen until you can remove the border.
  6. HP Envy 14 Screen Replacement: 6 단계, 이미지 1/3 HP Envy 14 Screen Replacement: 6 단계, 이미지 2/3 HP Envy 14 Screen Replacement: 6 단계, 이미지 3/3
    • Use the 3mm Phillips Screwdriver to remove the 4 black screws found on the metal tabs above and below the corners of the screen.
    • Don't get confused with the other black screws on the top corners. The ones you want to remove are located closer to the middle of the screen.
    • Lean the laptop cover back and unscrew the bottom 2 screws first so that the screen doesn't fall over as you are removing the screws.
    • Put these 4 screws in a separate container so they do not get mixed up with the 2 screws you already removed.
  7. HP Envy 14 Screen Replacement: 7 단계, 이미지 1/1
    • Now that the screen is not screwed in, place it face down on the keyboard.
  8. HP Envy 14 Screen Replacement: 8 단계, 이미지 1/3 HP Envy 14 Screen Replacement: 8 단계, 이미지 2/3 HP Envy 14 Screen Replacement: 8 단계, 이미지 3/3
    • Gently peel off the bar code sticker that is connected to the video cable connector.
  9. HP Envy 14 Screen Replacement: 9 단계, 이미지 1/2 HP Envy 14 Screen Replacement: 9 단계, 이미지 2/2
    • Remove the video cable from the connector by gently pulling the gray tab out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Noelle Ly
회원 가입일: 09/29/15
192 평판
안내서 1개 작성함
Cal Poly, Team 10-5, Green Fall 2015 Cal Poly, Team 10-5, Green Fall 2015 회원
CPSU-GREEN-F15S10G5
3 회원들
안내서 4개 작성하였습니다
댓글 2개
GIbt ein neues Modell (Spectre)... da wirds mit dem Display dank Verklebung echt sch....
willbjoern - 답글
Hi, do you think this would work with HP Envy 15 TouchSmart? For blank screen problem, if it is not the display, it may be the ribbon. Which one is the ribbon in your instructions above? Thanks!
Agung Adhiasto - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 24
전체 시간: 5,206
