주요 콘텐츠로 건너뛰기
HP Envy 15-u001dx Screen Replacement
필요한 것
  1. HP Envy 15-u001dx Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Remove the two screw covers located in the bottom corners of the screen and the 2.5 mm Phillips #0 screws underneath them.
    • If these screws are not removed and you separate the bottom portion of the screen, you will not be able to refasten the screen to the back because the screw tab will break.
  2. HP Envy 15-u001dx Screen Replacement: 2 단계, 이미지 1/2 HP Envy 15-u001dx Screen Replacement: 2 단계, 이미지 2/2
    • Only after removing the two bottom corner screws in Step 1, separate the screen from the back using an opening tool.
  3. HP Envy 15-u001dx Screen Replacement: 3 단계, 이미지 1/1
    • Remove the two 2.5 mm Phillips #0 screws with a Phillips#0 Screwdriver.
  4. HP Envy 15-u001dx Screen Replacement: 4 단계, 이미지 1/1
    • Detach the webcam from the damaged screen using spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. HP Envy 15-u001dx Screen Replacement: 5 단계, 이미지 1/1
    • Gently detach small white connector with spudger.
  6. HP Envy 15-u001dx Screen Replacement: 6 단계, 이미지 1/1
    • Gently remove the tape with the wire to completely separate the screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joshua Madden
회원 가입일: 09/25/16
670 평판
안내서 1개 작성함
USF Tampa, Team 9-4, Lacy Fall 2016 USF Tampa, Team 9-4, Lacy Fall 2016 회원
USFT-LACY-F16S9G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 18
전체 시간: 1,560
