주요 콘텐츠로 건너뛰기
HP Envy 15-u001dx Wireless Network Card Replacement
필요한 것
  1. HP Envy 15-u001dx Wireless Network Card Replacement, HP Envy 15-u001dx Disassembly: 1 단계, 이미지 1개 중 1개
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Wireless Network Card Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Wireless Network Card Replacement: 3 단계, 이미지 1개 중 1개
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Wireless Network Card Replacement: 4 단계, 이미지 1개 중 1개
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Wireless Network Card Replacement: 5 단계, 이미지 2개 중 1개 HP Envy 15-u001dx Wireless Network Card Replacement: 5 단계, 이미지 2개 중 2개
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Wireless Network Card Replacement, Wireless Network Card: 6 단계, 이미지 1개 중 1개
    • Remove the Phillips #0 4.5 mm screw from the wireless network card located in the back, right side of the interior.
  7. HP Envy 15-u001dx Wireless Network Card Replacement: 7 단계, 이미지 1개 중 1개
    • Use the spudger to remove the antenna connector attached to the black wire labeled "1".
  8. HP Envy 15-u001dx Wireless Network Card Replacement: 8 단계, 이미지 1개 중 1개
    • Detach the antenna connector for the white wire labeled "2".
  9. HP Envy 15-u001dx Wireless Network Card Replacement: 9 단계, 이미지 1개 중 1개
    • Gently remove the card from its slot by pulling.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Dakota Presley
회원 가입일: 10/05/16
885 평판
안내서 6개를 작성함
USF Tampa, Team 9-4, Lacy Fall 2016 USF Tampa, Team 9-4, Lacy Fall 2016 회원
USFT-LACY-F16S9G4
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 726
