주요 콘텐츠로 건너뛰기
HP Envy 17-3070NR Hard Drive Replacement
필요한 것
  1. HP Envy 17-3070NR Hard Drive Replacement, Back Cover: 1 단계, 이미지 1/2 HP Envy 17-3070NR Hard Drive Replacement, Back Cover: 1 단계, 이미지 2/2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Hard Drive Replacement: 2 단계, 이미지 1/3 HP Envy 17-3070NR Hard Drive Replacement: 2 단계, 이미지 2/3 HP Envy 17-3070NR Hard Drive Replacement: 2 단계, 이미지 3/3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/3 HP Envy 17-3070NR Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/3 HP Envy 17-3070NR Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3/3
    • Remove the four 3.7mm Phillips screws that hold the hard drive onto the computer.
    • Remove the hard drive by lifting it out of its cavity.
    • Unplug the hard drive cable that connects it to the main assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jasper Lewin
회원 가입일: 04/21/15
750 평판
안내서 6개 작성하였습니다
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 회원
CPSU-AMIDO-S15S14G8
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 4,492
