주요 콘텐츠로 건너뛰기
HP Envy 17-3070NR Optical Drive Replacement
필요한 것
  1. HP Envy 17-3070NR Optical Drive Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 HP Envy 17-3070NR Optical Drive Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Optical Drive Replacement: 2 단계, 이미지 3개 중 1개 HP Envy 17-3070NR Optical Drive Replacement: 2 단계, 이미지 3개 중 2개 HP Envy 17-3070NR Optical Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: 3 단계, 이미지 3개 중 1개 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: 3 단계, 이미지 3개 중 2개 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: 3 단계, 이미지 3개 중 3개
    • Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
    • Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
    • Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
    • Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
  4. HP Envy 17-3070NR Optical Drive Replacement: 5 단계, 이미지 3개 중 1개 HP Envy 17-3070NR Optical Drive Replacement: 5 단계, 이미지 3개 중 2개 HP Envy 17-3070NR Optical Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
결론
작성자
7다른 기여자 명과 함께
Jon Fuson
회원 가입일: 04/21/15
140 평판
안내서 1개를 작성함
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 회원
CPSU-AMIDO-S15S14G8
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 1,352
