주요 콘텐츠로 건너뛰기
HP Envy 17-3070NR RAM Replacement
필요한 것
  1. HP Envy 17-3070NR RAM Replacement, Back Cover: 1 단계, 이미지 1/2 HP Envy 17-3070NR RAM Replacement, Back Cover: 1 단계, 이미지 2/2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR RAM Replacement: 2 단계, 이미지 1/3 HP Envy 17-3070NR RAM Replacement: 2 단계, 이미지 2/3 HP Envy 17-3070NR RAM Replacement: 2 단계, 이미지 3/3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR RAM Replacement, RAM: 3 단계, 이미지 1/3 HP Envy 17-3070NR RAM Replacement, RAM: 3 단계, 이미지 2/3 HP Envy 17-3070NR RAM Replacement, RAM: 3 단계, 이미지 3/3
    • Press down on both tabs on either side of the top RAM stick.
    • The RAM will slightly pop out and you will be able to slide it out of it's cavity.
    • Repeat the same process for the second stick of RAM if needed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Abby Lentz
회원 가입일: 04/21/15
586 평판
안내서 4개 작성하였습니다
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 회원
CPSU-AMIDO-S15S14G8
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 11
전체 시간: 762
