주요 콘텐츠로 건너뛰기
HP Envy 17-3070NR Subwoofer Replacement
필요한 것
  1. HP Envy 17-3070NR Subwoofer Replacement, Back Cover: 1 단계, 이미지 1/2 HP Envy 17-3070NR Subwoofer Replacement, Back Cover: 1 단계, 이미지 2/2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Subwoofer Replacement: 2 단계, 이미지 1/3 HP Envy 17-3070NR Subwoofer Replacement: 2 단계, 이미지 2/3 HP Envy 17-3070NR Subwoofer Replacement: 2 단계, 이미지 3/3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: 3 단계, 이미지 1/3 HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: 3 단계, 이미지 2/3 HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: 3 단계, 이미지 3/3
    • Unscrew the three 6.5mm Phillips shoulder screws that connect the subwoofer to the computer.
    • Disconnect the red and black subwoofer cable from the system board by pulling it upwards.
    • Remove the subwoofer by pulling straight up from the main assembly.
결론
Abby Lentz
회원 가입일: 04/21/15
586 평판
안내서 4개 작성하였습니다
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 회원
CPSU-AMIDO-S15S14G8
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 9
전체 시간: 522
