주요 콘텐츠로 건너뛰기
HP Envy 17-J013CL Battery Replacement
필요한 것
  1. HP Envy 17-J013CL Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Battery Replacement: 2 단계, 이미지 1/1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Battery Replacement: 3 단계, 이미지 1/3 HP Envy 17-J013CL Battery Replacement: 3 단계, 이미지 2/3 HP Envy 17-J013CL Battery Replacement: 3 단계, 이미지 3/3
    • Pull the battery out and let go of the battery slider.
결론
To reassemble your device, line up the battery and place it down into the metallic prongs for a stable connection.
다른 2명이 해당 안내서를 완성하였습니다.
Matt McBride
회원 가입일: 02/02/17
845 평판
안내서 6개 작성하였습니다
USF Tampa, Team 16-6, Blackwell Spring 2017 USF Tampa, Team 16-6, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G6
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
where does one buy a replacement battery for this HP envy17?
brandondelcastillo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 2,001
