주요 콘텐츠로 건너뛰기
HP Envy 17-J013CL Memory Module Replacement
필요한 것
  1. HP Envy 17-J013CL Memory Module Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Memory Module Replacement: 2 단계, 이미지 1/1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Memory Module Replacement: 3 단계, 이미지 1/3 HP Envy 17-J013CL Memory Module Replacement: 3 단계, 이미지 2/3 HP Envy 17-J013CL Memory Module Replacement: 3 단계, 이미지 3/3
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL Memory Module Replacement, Back Panel: 4 단계, 이미지 1/2 HP Envy 17-J013CL Memory Module Replacement, Back Panel: 4 단계, 이미지 2/2
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL Memory Module Replacement: 5 단계, 이미지 1/1
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL Memory Module Replacement, Memory Module: 6 단계, 이미지 1/2 HP Envy 17-J013CL Memory Module Replacement, Memory Module: 6 단계, 이미지 2/2
    • Locate the memory stick inside.
  7. HP Envy 17-J013CL Memory Module Replacement: 7 단계, 이미지 1/2 HP Envy 17-J013CL Memory Module Replacement: 7 단계, 이미지 2/2
    • On both sides of the module, place a thumb on each of the metallic holding pins.
    • Gently pull on the pins to release the spring holding in the module.
  8. HP Envy 17-J013CL Memory Module Replacement: 8 단계, 이미지 1/2 HP Envy 17-J013CL Memory Module Replacement: 8 단계, 이미지 2/2
    • Gently slide the module out of the memory slot.
    • Pay in mind of the module's orientation as it will only go in one way with a little gap in the module to identify orientation.
결론
Matt McBride
회원 가입일: 02/02/17
845 평판
안내서 6개 작성하였습니다
USF Tampa, Team 16-6, Blackwell Spring 2017 USF Tampa, Team 16-6, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 6
전체 시간: 663
