주요 콘텐츠로 건너뛰기
HP Envy 17-J013CL WLAN Module Replacement
필요한 것
  1. HP Envy 17-J013CL WLAN Module Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL WLAN Module Replacement: 2 단계, 이미지 1/1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL WLAN Module Replacement: 3 단계, 이미지 1/3 HP Envy 17-J013CL WLAN Module Replacement: 3 단계, 이미지 2/3 HP Envy 17-J013CL WLAN Module Replacement: 3 단계, 이미지 3/3
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL WLAN Module Replacement, Back Panel: 4 단계, 이미지 1/2 HP Envy 17-J013CL WLAN Module Replacement, Back Panel: 4 단계, 이미지 2/2
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL WLAN Module Replacement: 5 단계, 이미지 1/1
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL WLAN Module Replacement, WLAN Module: 6 단계, 이미지 1/2 HP Envy 17-J013CL WLAN Module Replacement, WLAN Module: 6 단계, 이미지 2/2
    • Locate the WLAN module.
  7. HP Envy 17-J013CL WLAN Module Replacement: 7 단계, 이미지 1/2 HP Envy 17-J013CL WLAN Module Replacement: 7 단계, 이미지 2/2
    • Use a PH1-screwdriver to remove the 7mm screw from the motherboard.
  8. HP Envy 17-J013CL WLAN Module Replacement: 8 단계, 이미지 1/2 HP Envy 17-J013CL WLAN Module Replacement: 8 단계, 이미지 2/2
    • Lift the black and white wire from the module. Removing the wires from the ends will have a distinct popping noise.
    • Remember to put the white wire on the left side of the module and the black wire on the right side. Failure to do so may cause issues.
  9. HP Envy 17-J013CL WLAN Module Replacement: 9 단계, 이미지 1/2 HP Envy 17-J013CL WLAN Module Replacement: 9 단계, 이미지 2/2
    • Gently pull out the module away from the motherboard.
    • Make sure to put the module back in the correct orientation designated by the little arch in the end of the module.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matt McBride
회원 가입일: 02/02/17
845 평판
안내서 6개 작성하였습니다
USF Tampa, Team 16-6, Blackwell Spring 2017 USF Tampa, Team 16-6, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 6
전체 시간: 338
