주요 콘텐츠로 건너뛰기
HP Envy 23-d060qd TouchSmart Hard Drive Replacement
필요한 것
  1. HP Envy 23-d060qd TouchSmart Hard Drive Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • Remove the one 13.5mm PH2 screw.
  5. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Unsnap the wire mechanism to release the hard drive.
  6. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Detach the hard drive assembly by pulling it out of the socket.
  7. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two 8.5mm PH2 screws on each side of the hard drive cover.
  8. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Detach the hard drive cover by sliding it off from the rest of the hard drive
    • Replace the old hard drive with your new hard drive.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Zachary Dicks
회원 가입일: 10/01/15
1,166 평판
안내서 7개를 작성함
Cal Poly, Team 5-10, Maness Fall 2015 Cal Poly, Team 5-10, Maness Fall 2015 회원
CPSU-MANESS-F15S5G10
4 회원들
안내서 14개를 작성함
2가이드 댓글
Thank you so much my hard drive is bad this is going to be a quick fix and save me money you made this for dummies I LOVE IT can u tell me when I replace the hard drive will I lose everything on my computer already such as photos,files, I have everything in office purchased on the computer ? If so is there a way not to lose anything
jessica Kramer - 답글
Yes you will, unless you back them up. All your data is stored on that hard drive.
Dane Elliott-Dyson -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 58
전체 시간: 7,706
